Sleeve the block and oil nozzle jet
Old 07-29-2006 | 07:26 PM
Danyellow02's Avatar
Default Sleeve the block and oil nozzle jet
Guys,
I am in the market to get the steel sleeve for my S engine block.
Someone from Laskey Racing told me that they might weld the oil nozzle which is shooting the oil from the bottom of the cylinder to provide axtra cooling to the piston. They said that if I chose the forced piston (CP) then I would not need that axtra cooling for the piston.
I am wondering if they don't use the oil jet, so
how could the wrist pin and the piston oil ring get the oil for lubrication?
I'd very much appreciate for any idea
Danh
Old 07-29-2006 | 09:08 PM
Sideways's Avatar
Pistons direct oil from the cylinder walls to the wrist pin by the action of the oil rings. There is adequate oil to the cylinderwalls without the oiljets.
Old 07-30-2006 | 09:09 AM
GDM S2K's Avatar
Had mine closed on be AEBS sleeved block
Old 07-30-2006 | 06:19 PM
Guys
Thank you very much for your helpful responds.
another "dump" question
when the aluminum block inserted the steel sleeve, is it any problem with the different material thermal expansion?
Thank you very much
Danh
lude92_si
05-22-2014 08:17 PM
Bigfootexpert
05-01-2012 09:31 AM
ChefJ
08-12-2007 09:36 PM
wannabuy
06-06-2006 09:50 AM
