simple injector controllers
Originally Posted by boostedf22c,Apr 2 2009, 12:18 PM
Sounds like you answered your own question then.
Not sure if this is what your looking for but Ballistic motorsports has a secondary fuel rail they use with the E-manage that delivers OEM like driveability. If you want do a search on the New England forum or get a hold of them.
I tend to not have much faith in injectors upstream when used for fuel enrichment. Assuming equal fuel gets to all cylinders is generally a bad assumption. Fuel and air don't travel the same way through an intake manifold. Injecting fuel in each runner is slightly more consistent and reliable.
You could probably just run it excessively rich with some upstream injectors and make it fly, but it's far from ideal.
I've seen one of the SOT/BRP beta testers running a 5th injector with a ultimate e-manage. I'm not sure if any of the other beta testers were using this.
The AP2 Vortech kit uses a Split Second timing and injector controller with a sub injector in the aftercooler.
I used to run a blue e-manage with 440cc RC's on a stock boost Vortech without a problem (no timing control though) except for an occasional Baro DTC and having to hold the throttle for cold starts without stalling.
^^^ Thanks for the info there Replicating something like the VT kit may be the answer. I'll have to research that a bit and see if it would allow me to suffice my needs.
BTW -before my tuner over fueled my motor to death with the FIC, I was able to run 10.5 psi on the stock timing map with the CTSC without any detonation, was a bit surprising, I figured there would need to be a bit at that point, but there just isn't enough lower/mid rpm boost, so with that, my goal is to recreate this boost/power level with a more reliable course of action, keeping the factory systems in place. Down the road if I decide to hit 12psi+ I think it would be prudent at that point to run a stand alone measure that will have the ability to retard timing.
Originally Posted by DeadZero,Apr 2 2009, 07:20 PM
don't cut corners when it comes to boost man. nothing good comes outta it in the long run just by trying to save a grand or 2.
Generally speaking some of the answer's to tuning related questions on s2ki start to sound like a broken record after a wile, EMS...EMS, just do an EMS. etc makes you wonder if most the members are just Perot's or if they actual are experienced with good insight.
I like to find the lines of where one tuning device or application warrants changes, to maximize performance and money spent. In my experience these lines are very blurred on s2ki, mostly from lack of insight and experience. I'd say this is more typical in the lesser to moderate boost applications. 10psi and under.
