ScienceofSpeed Walbro 400 & 450 Plug and Play Mounting Bracket Kit
Former Sponsor
The Walbro 400 and 450 LPH fuel pumps have become popular high-flow in-tank fuel pumps for the S2000. As many have found out, the Walbro 400/450 fuel pump does not fit in to the S2000 fuel pump carrier due to its enlarged turbine base that prevents the factory bracket from being able to be installed.
Now, ScienceofSpeed offers a plug and play mounting solution allowing the fuel pump to be easily installed in to the factory fuel pump carrier with out any modification. The factory mounting bracket is recreated out of 6061 aluminum billet CNC lathe and 4-axis CNC mill machined with a design that allows the pump to clip on to the factory fuel pump carrier. The kit includes everything required for installation including bracket, synthetic rubber noise-isolating cushion, machined 6061 aluminum base plate, stainless steel retainer ring, and ethanol compatible filter sock.
Kit is sold with or with out pump.
more info:
http://www.scienceofspeed.com/produc...0-450_Bracket/
Due to the high electrical current demand of these fuel pumps, fuel pump wiring must be upgraded. ScienceofSpeed offers fuel pump power kits which include new terminals to terminal fuel pump wires directly in to factory fuel pump carrier connector as shown in installed photos.
more info:
Damn I wish this was made a few years ago when the pump came out. I had to make a similar cup thing but had to ditch the snap fit for screws in the plastic housing. Plus I cut the housing because it seemed the pump was hanging too low? I'm in for one of these good job on this SOS!! Just like 2 years too late making it
Great job SOS! Keep up the good work!
OK...so I'm gonna say it... Now come out with a C38 series Rotrex S/C system! We who have em like the less noise of the Rotrex blowers vs the Paxton's. My only reason for not getting an SOS 1200 kit!
Former Sponsor
