ScienceofSpeed releases supercharger system
Old 04-27-2009 | 06:17 PM
  #561
camuman's Avatar
Originally Posted by Chris@SoS,Apr 27 2009, 07:52 PM
Please place the IAT sensor into the silicone elbow boot (this should be on pg 26 of your manual, if you don't have this in your manual (the current rev is 3/27/09), just let me know and I will e-mail you this page).
The SL compressor is delivered pre-filled. The level is checked with the dip stick when the compressor is installed. The kit includes 3 bottles of additional oil for future changes.
Cheers,
-- Chris
do you move the iat on 00-05 cars? why do you move it? i have notiiced the intake mani is a interwarmer of sorts. i swear it heats the air near 20 degrees. well, ither its warming the air or the iat gets heat soaked. any info appreciated.
Old 04-27-2009 | 06:29 PM
  #562
ScienceofSpeed's Avatar
Former Sponsor
We do not move the IAT in the 2000-05 S2000. Honda moved the IAT sensor in 2006 to the intake boot. The sensor is installed in the silicone intake boot in our kit.
Cheers,
-- Chris
Old 04-28-2009 | 02:12 PM
  #563
smmcc's Avatar
Unhappy
Originally Posted by Chris@SoS,Apr 27 2009, 05:06 PM
No, these are completely different parts.
There are two common types of ways to cool inlet charge temperature, air to air and air to liquid. In either case, a radiator core is placed between the compressor (turbocharger or supercharger) and engine. In an air to air system, ambient air flow passes across this core reducing the temperature of pressurized air passing through this exchanger. In a air to liquid system, liquid is passed across the core reducing temperature of this same pressurized air. Whether air or liquid cooled, this system is called an aftercooler system as the core is placed between the compressor and engine. The term "intercooler" is not applicable to 99% of automotive turbo/supercharger designs as this refers to a method of cooling between compressors. However, it's commonly misused as describing an air-air aftercooler system.
In our supercharger system, we use a liquid cooled aftercooler. The liquid passing across the core is circulated by a water pump that transfers it to a separate radiator mounted in front of the vehicle. This separate radiator is called a heat exchanger. This is best illustrated by this diagram:
There is lots of information on these different designs available online. If you have any questions about our specific design, feel free to post or drop us a line.
regards,
-- Chris
Thanks for clearing it up. Very helpful information. With that said another dumb question, is it possible to run an air to air aftercooler with your system?
Old 04-28-2009 | 04:35 PM
  #564
Sellout's Avatar
It's always possible to run an air/air setup. All you need to do is sell off the air/water setup and get yourself an intercooler and some piping...
(i know i know, technically it's an aftercooler, but intercooler is the word everyone uses besides the supercharger boyz)
Old 11-19-2009 | 11:30 PM
  #565
Oly_S2k's Avatar
Whats the highest amount of boost that you can safely run on stock internals?
Old 11-20-2009 | 01:52 PM
  #566
s2000Junky's Avatar
Originally Posted by juntuned,Jan 18 2009, 06:37 PM
theeee ONLY reason this kit would be better than the KW is the expandability past 360rwhp on a stock motor out of the box...
which I have yet to hear an explanation for...
Dude an old Comptech Novi1000 has more boost and expandable options/power potential then a current KW
Old 11-20-2009 | 04:16 PM
  #567
kitwetzler's Avatar
Hey SoS, have you guys had a chance to put together a stage 2 DBW Kit based on the Hondata Flashpro instead of a Kpro? I'd be interested in that.
Old 11-20-2009 | 07:18 PM
  #568
leo520's Avatar
can u guys sell me an intake elbow for the supercharge kit?
i need one for a year model 2007..
thx
Leo
Old 11-21-2009 | 07:48 AM
  #569
CodyLX450's Avatar
Give them a few more days. Thats the route I'm going for now.
Old 11-23-2009 | 12:51 PM
  #570
NoRegrets78's Avatar
Here comes the stupid questions, just seeing if I understand this correctly (FI Noob).
Stage 1 kit, totally plug and play ready to go once installed.
Stage 2 kit, MUST be tuned before it can be used (KPro upgrade).
Thanks guys!
Quick Reply: ScienceofSpeed releases supercharger system
