ScienceofSpeed releases supercharger system
Old 04-26-2009 | 06:48 PM
  #551
svencarlson07's Avatar
sorry if i missed this but if the stage 2 with krpo for my 06..will i be able 2 pass ny inspection?
Old 04-26-2009 | 08:48 PM
  #552
smmcc's Avatar
kind of a dumb question, but is the heat exchanger the same as an intercooler? Or does it play the same rolw with just a different name?
Old 04-27-2009 | 05:25 AM
  #553
stitos2k's Avatar
Not too likely unless you go to a private guy who is "friendly" or "clueless".
Old 04-27-2009 | 06:12 AM
  #554
suprmonky73's Avatar
yes
SOS Heat Exchanger Info
Old 04-27-2009 | 04:44 PM
  #555
ScienceofSpeed's Avatar
Former Sponsor
Originally Posted by MasterForce,Apr 23 2009, 07:02 AM
OK some questions.
I want to get the stage 2 with the k-pro. so the k pro isnt tuned and i need to take it to a tuner??
also for the install did you guys lift the car up??
as far as tools, anything special required other than a breaker bar or a torque wrench? Thanks!
The K-Pro comes with base map. However, my recommendation is to install the system, then drive to the tuner with the stock ECU and stock injectors in place with the supercharger belt off. Then, install these parts at the tuner's shop.
You will need to raise the car slightly to drain the oil and change the fitting (engine oil fed system) or to install the drain line (self lubricating system).
You will need the factory crankshaft pulley removal tool, or the much less expensive aftermarket tool: Powerbuilt 648796 (search this on Amazon.com).
Cheers,
-- Chris
Old 04-27-2009 | 04:52 PM
  #556
Former Sponsor
Originally Posted by pinstriped06,Apr 23 2009, 01:04 PM
hey where did u guys put yur iat sensor? and hey wasnt the sl blower suposed to come prelubed?
Please place the IAT sensor into the silicone elbow boot (this should be on pg 26 of your manual, if you don't have this in your manual (the current rev is 3/27/09), just let me know and I will e-mail you this page).
The SL compressor is delivered pre-filled. The level is checked with the dip stick when the compressor is installed. The kit includes 3 bottles of additional oil for future changes.
Cheers,
-- Chris
Old 04-27-2009 | 04:53 PM
  #557
Former Sponsor
Originally Posted by CROD,Apr 23 2009, 02:11 PM
also get a 70mm exhaust
We've shown the best gains with 70mm exhausts. Our favorite is the T1-R because it does not have bad interior resonance like some of the others with this larger diameter. I use this on my daily driver:
http://www.scienceofspeed.com/products/exh...l_70mm_Sparrow/
Cheers,
-- Chris
Old 04-27-2009 | 04:55 PM
  #558
Former Sponsor
OK some questions.
As noted by CROD, the standard stage 1 06-08 get a reflashed ECU tuned specificly for the supercharger system. The Dual ECU K-Pro is only really needed if you are planning to exceed 10 PSI and want finer fuel, ignition, and VTEC control.
Cheers,
-- Chris
Old 04-27-2009 | 04:57 PM
  #559
Former Sponsor
Originally Posted by s2k8,Apr 26 2009, 02:37 PM
Question to guys who installed their superchargers. I was intalling the bracket onto the supercharger as per diagram, however the supercharger outlet to aftercooler its on the other side comperared to the diagram in the instruction manual. Am I supposed to loosen it and flip it? Thanks!
Please see installation guide page 9 section "Volute Clocking".
Cheers,
-- Chris
Old 04-27-2009 | 05:06 PM
  #560
Former Sponsor
No, these are completely different parts.
There are two common types of ways to cool inlet charge temperature, air to air and air to liquid. In either case, a radiator core is placed between the compressor (turbocharger or supercharger) and engine. In an air to air system, ambient air flow passes across this core reducing the temperature of pressurized air passing through this exchanger. In a air to liquid system, liquid is passed across the core reducing temperature of this same pressurized air. Whether air or liquid cooled, this system is called an aftercooler system as the core is placed between the compressor and engine. The term "intercooler" is not applicable to 99% of automotive turbo/supercharger designs as this refers to a method of cooling between compressors. However, it's commonly misused as describing an air-air aftercooler system.
In our supercharger system, we use a liquid cooled aftercooler. The liquid passing across the core is circulated by a water pump that transfers it to a separate radiator mounted in front of the vehicle. This separate radiator is called a heat exchanger. This is best illustrated by this diagram:
There is lots of information on these different designs available online. If you have any questions about our specific design, feel free to post or drop us a line.
regards,
-- Chris
Quick Reply: ScienceofSpeed releases supercharger system
