ScienceofSpeed releases supercharger system
Old 03-06-2009 | 04:55 AM
  #281
s2000442's Avatar
Originally Posted by suprmonky73,Mar 6 2009, 05:51 AM
so maybe im blind but ive read through the entire thread and the SoS website, but with the basic aftercooled SC setup (4895$) there is no AEM EMS or KPro that you need?
it just bolts straight up and you can upgrade those later?
Yes. It uses its own "black box" and FMU to control fuel.
Old 03-06-2009 | 06:41 AM
  #282
pinstriped06's Avatar
4 weeks in counting....what am i gnna do!!??
Old 03-06-2009 | 09:15 AM
  #283
suprmonky73's Avatar
so is it safe to make the assumption that there is no "tuning" needed? once you bolt it all on and finish the install its essentially "good to go" and nothing else is needed?
Old 03-06-2009 | 09:50 AM
  #284
s2000442's Avatar
Correct...
Old 03-06-2009 | 10:05 AM
  #285
DannyCoolBeans's Avatar
Originally Posted by s2000442,Mar 6 2009, 10:50 AM
Correct...
....I'm pretty sure you have to get it tuned so the FMU is set at its best setting. Right??
Also what does this use to pull timing? It's own "black box" ??
Old 03-06-2009 | 10:52 AM
  #286
kix's Avatar
kix
I'm curious about the FMU as well. As we have seen with the greddy kits, not all cars were functioned properly with the basemap provided. By this same logic, how can the FMU be more reliable?
Old 03-06-2009 | 10:59 AM
  #287
s2000442's Avatar
This is probably something Chris should answer but no, you do not need a tune with the fmu. If you want to check that the fuel pressure is rising as rpm rises you can get a fuel pressure guage to check. If you have an a/f guage that will show you were the ratio is. These units tend to run on the rich side anyway for safety. The "black box" is essentially the timing control unit that pulls timing and fools the map sensor into thinking their is no boost. The fmu raises the fuel pressure as rpm increases so that enough fuel can be run through the stock injectors.
It is a similar system used by comptech and vortech for the 00-05 cars and is good for about 7psi max and 300whp or so. All these units are bolt and go and do not require tuning...essentially because there is nothing to tune. The parts either work or they do not. You can run a boost guage to make sure your belt does not slip and the a/f guage to make sure the fuel pump and fmu are running well. These are not essential but I would add them for piece of mind anyway.
Old 03-06-2009 | 11:56 AM
  #288
awesome, thanks for the clarification s2000442
from what ive read so far it seems like this is the most user-friendly SC kit... at least from my perpective as someone brand new to this FI game
Old 03-06-2009 | 04:51 PM
  #289
s2000442
From what i remember(i can be wrong but) when i spoke to Chris he said that the FMU is tuneable, which comes with instructions. He aslo said you need to tune this right away when you install the system. It s not meant to be floored untill you tune it
Old 03-06-2009 | 06:24 PM
  #290
jbell's Avatar
Banned
does anyone know if the tensioning system is the same as the vortech?
i haven't seen a vortech's... and i know the comptech uses a slide...
so basically what i'm asking is: is SOS's tensioning system UNIQUE to their kit?
Quick Reply: ScienceofSpeed releases supercharger system
