ScienceofSpeed releases supercharger system
Old 01-17-2009 | 09:03 AM
  #91
DeadZero's Avatar
Originally Posted by kelz12' date='Jan 15 2009, 08:36 AM
Hmm? I was thinking KW, but with the AVAILABILITY! And the COST of this kit, I may have to reconsider.
Can anyone chime in some comparisons regarding performance by first hand experience?
Great Kit!
why would you even consider the kw at all anymore?? LOL SOS s/c has more potential to make much more power, costs $$$ less right off the bat. jeez KW just got wiped out the moment they released this kit haha.
Old 01-17-2009 | 02:07 PM
  #92
bjjs2k's Avatar
how hard is it to tighten the belt on this one? I know with the vortech you have to jackup the car and do it from the bottom of the car(and not alot of room either). Do you tighten the belt on these just like the vortech's?
Old 01-17-2009 | 02:55 PM
  #93
s2k_suprchrgd's Avatar
chris,
is the supercharger and aftercooler capable of supporting 500+ whp??
or do you think i will need to upgrade the supercharger and aftercooler??
my goal is to make 550 whp. if this kit is capable of making 500+whp, i will consider buying the kit..
BTW the kit looks great... good price too
thanks,
Nikhil
Old 01-17-2009 | 06:19 PM
  #94
juntuned's Avatar
oh really? please explain to me how???? just curious.....
they make the same hp roughly....360rwhp for the stage 2 and high boost respectively!
where does this blower max out at?.... I dont want to see dyno's of built motor's with the kit. Just bolt on and go... what is the potential of this kit????
Old 01-17-2009 | 06:40 PM
  #95
DeadZero's Avatar
who knows. but. KW max's at 10lbs of boost. at 360-370WHP (DYNAPACK)
The SOS S/C already can boost more then 15lbs of boost and theres dyno's of them with less 10lbs of boost making 364whp (dynapack) (2006-2008 models)
But the potential of this kit is much greater then KW. Go to SOS website. After looking at there stock boost dyno's it RIGHT AWAY will blow away the stage 2 "high boost" kraftwerk kits outta the water.
Old 01-17-2009 | 07:07 PM
  #96
juntuned's Avatar
No, It by no means blows kw out of the water... but this does peak my interest...
I read on the dyno of the 450+ car the boost level was 16.7???? So chris, educate us all.....
with a simple pulley swap you can have 12.. 14... 16.. psi of boost?????
would you please list ALL of the pulley options and explain how one could obtain (400hp bolt on and go)
Old 01-17-2009 | 09:52 PM
  #97
DeadZero's Avatar
sorry maybe blown outta the water might be too much. BUT it does generate more potential power then the KW. Providing more boost.
Old 01-18-2009 | 03:14 AM
  #98
Nagata-San74's Avatar
Hello,
I'm interested in your aftercooled SC kit for my 2003 Ap1.
I need to know what's included in the kit,
if there are injectors pump, and EMS
And also a price shipped to Switzerland (CH-1004)
Thanks
Fab.
Old 01-18-2009 | 05:12 AM
  #99
s2000442's Avatar
Originally Posted by Nagata-San74' date='Jan 18 2009, 04:14 AM
Hello,
Thanks
Fab.
You will get a FMU, fuel pump and some electronics you splice into your ecu to control timing. This kit relies on rising fuel pressure with existing injectors to create 6lbs of boost. It is similar to the old comptech set up.
Old 01-18-2009 | 09:39 AM
  #100
Ok, thanks for informations.
So all hardware given, I just add an EMS and maybe injectors, and let's roll, right ?
Quick Reply: ScienceofSpeed releases supercharger system
