Sc water pump issue
Old 01-04-2012, 11:09 AM
jordannn93's Avatar
Default Sc water pump issue
Upgraded to a front mount heat exchanger recently and now my water pump is making noise but doesn't seem to be pumping. It worked with the stock heat exchnger . I have a Bosch pump. I will include a video
http://i771.photobucket.com/albums/x...l/596547de.mp4
http://www.siliconeintakes.com/produ...oducts_id=1001
What I have now
*update
http://i771.photobucket.com/albums/x...l/93463fbe.mp4
Old 01-04-2012, 11:19 AM
s2000Junky's Avatar
Same thing happened to me, check for any kinked hoses to be sure, but likely just need to replace it. The brushes wear out eventually, plus there is much more demand on the pump to move all that extra water now. Replace with a bigger pump.
Old 01-04-2012, 11:36 AM
jordannn93's Avatar
Thanks for the fast response! What would be some choices I have for a pump? Don't want to buy the SOS one for $300+
Old 01-04-2012, 11:55 AM
s2000Junky's Avatar
Yeah I wouldn’t either. There are some good choices for $100-150 price range but I don’t have any links for you off the top of my head. I'm confident you can do a search in this forum and find out, you’re not the first with this question. My buddy bought one for his large heat exchanger, and I think it was a Bosch in fact. I think he got it off ebay. SOS takes the same pump and marks up the price double.
Old 01-04-2012, 12:00 PM
jordannn93's Avatar
I'll look on eBay. What's a good flow rate? Around 7 gallon per minute?
Old 01-04-2012, 05:29 PM
99SH's Avatar
Some good info in this post: https://www.s2ki.com/s2000/topic/792...c-aftercooler/
Old 01-04-2012, 10:01 PM
jordannn93's Avatar
Read that. Still kinda confused on what pump .
http://www.apeusa.com/html/jabsco.html
CM30P7-1 10-24504-03 or
10-24489-04 20mm
(3/4 in) 12V 6.9 g/m @ 0.1 bar $145
That seems like the one to go with ?
Old 01-05-2012, 04:43 AM
99SH's Avatar
FYI... the SOS unit flows 7.5 g/m and costs $175 (i think)
Old 01-05-2012, 06:54 AM
jordannn93's Avatar
http://www.scienceofspeed.com/produc...pump_assembly/
Does it matter How I have the pump mounted ? Like upside down like I have it ?
Old 01-05-2012, 08:56 AM
jordannn93's Avatar
Got pump working . How does the flow look? It will probably flow a little better if the car was started
Quick Reply: Sc water pump issue
