replacement parts for vortech SC
im missing some parts (bolts, washers, spacers and more) on my vortech SC kit. where can i find them??
i have the part# of what i need.
do i have to contact vortech?
thanks for reading.
thanks for reading.
looks like i have to wait untill tuesday...
i wonder if they carry all the stuff.
im going to need alotttttttta stuff.
Part# Description Qty.
7A250-075 1/4-20X.75 SHCS 2
4PFA010-031 TENSIONER ADJ. SCREW LOCATOR 1
7PA375-500 TENSIONER SCREW 1
7B500-325 TENSIONER ARBOR 1
4HS017-051 TENSIONER SPACER 1
4HS017-011 RIBBED IDLER SPACER 1
4HS017-031 UPPER S/C PLATE SPACER 4
4HS017-021 12MM S/C BOSS SPACER 1
4HS017-041 S/C PLATE SPACER(TO STOCK IDLER) 1
7F375-028 3/8-24 PRESS NUT 4
7B375-350 3/8-24 X 3.50 4
7C010-115 M10 X 1.25 X 115 BOLT 1
7J010-002 M10 WASHER (.08 THK.) 2
7C060-622 M6 X 1.00 X 158 STUD 2
7C010-049 M10 X 1.25 X 50 BOLT 1
7C060-080 M6 X 1.00 X 80 BOLT 3
7C012-050 M12 X 1.75 X 50 BOLT 1
7A375-124 3/8-16 X 1.25 7
7A375-350 3/8-16 X 3.50 1
7K375-040 3/8 AN WASHER 12
7J006-093 M6 WASHER 5
7F006-093 M6 NUTS 2
7J012-092 M12 WASHER 2
7F500-030 1/2-20 JAM LOCK NUT 1
2A017-016 3/8 ID BEARING PILOT (6203 BRG) 1
4GF016-160 RIBBED 3'' IDLER 1
7C080-046 M8 X 1.25 X 45 SHCS 2
7A312-100 5/16-18 X 1.0 HXHD 2
7K312-001 5/16 AN WASHER 2
7F006-093 M6 NUTS 2
I'm guessing that you bought used? If not, Vortech should send you the parts no charge. Otherwise, like the last guy said, most of those you can get at the hardware store. If you don't know what some of the names mean, ask. I'm sure there are mech. engineers here that can help. (I took 1 year of mech. engineering so I can help on a few of them).
yeah i bought my vortech about 6 months ago and i installed the kit after about a month.when i took it to the guy that was going to install it for me he said i was missing some bolts and other misc parts for the install.called vortech and they sent it right over...i think you should just give vortech a call,thats your best bet.
Akilldema
07-13-2007 03:09 PM
