remote mount turbo anyone tried them?
Old 03-08-2010, 10:03 AM
S2Kart's Avatar
If you size the charge pipe for 240 feet/second (75mm diameter) then the lag is 40 milliseconds. The big advantage with remote mount would be to keep the heat out of the engine bay.
I'm building a remote mount setup using a precision 5857 dbb right now. There is lots of space since I removed the well in the trunk, plus you don't need a muffler. Should be interesting.
Old 03-08-2010, 10:07 AM
devs2k's Avatar
Heffner Lambo Gallardo
Twin Turbo - both turbos are mounted downstream of the catalytic converter. Water-to-air intercoolers were used.
Old 03-08-2010, 12:42 PM
Revenge's Avatar
Can't wait to see what you come up with!
Old 03-08-2010, 12:55 PM
s2kswe's Avatar
Omg omg, pictures please!!!
Old 03-08-2010, 03:02 PM
s2k aok's Avatar
i remember when i first saw a remote mount, it was putting a turbo at the rear bumper of an integra. easy install i'd guess, i'm all for easy installs...
Old 03-08-2010, 05:17 PM
scheister's Avatar
Best remote mount evar
Old 03-08-2010, 08:18 PM
Artisan7471's Avatar
That thing is hawt . hahah I guess thats one way to keep the heat out of the engine bay.
Old 03-08-2010, 08:26 PM
AusS2000's Avatar
And nice and close to the fuel tank.
Old 03-08-2010, 08:49 PM
MugenRioS2k's Avatar
Remote turbo + one of these http://www.aerocharger.com/
expensive yes but the best of both worlds ( boost response and top end flow) since it is variable vane
Think how simple the install would be because it has self contained lubrication so no oil lines to run.
The closest you can get to true bolt on and tune
The only problem with these is the lower efficient % for the same flow /pr.
However with the return piping and a decent front mount efficiency/heat solved.
Old 03-08-2010, 09:58 PM
jari8378's Avatar
^^ i want.
Quick Reply: remote mount turbo anyone tried them?
