RC 1200cc injectors for street use
I am thinking about changing out my RC 1000cc injectors for a set of RC 1200cc injectors. I plan to push over 700hp on my 2.5L turbo setup and was worried about killing the injectors when I run a higher boost levels. I did some calculations on a site and it said I would be over 90% duty cycle with my current injectors, if I were to push 700hp.
Would the drive abilty and tune be affected much with the use of 1200cc injectors?
I know 1000cc are usally as far as some people recommend for street use but I want that little extra for insurance.
Thanks
Thanks
what kind of fuel pressure are u guys running? i know you can cheat to a certain extent with raising the fuel pressure to gain some more flow from the injector, but wondering what most are runnin for FI.
1200cc injectors are huge! using rc engineerings calculator, you can use a 750cc injector and make 500 at the crank with 75psi in the fuel rail and still be at 80% duty cycle. does anyone do this?
