radiator hose size
2nd Thread today asking "How long should my hose be and how thick"
Ask your wife/GF
Comptech uses 3/4" HOSE
If you can mount the replacement radiator, I am sure you can measure hose. Buy MORE than you need and cut it to size, you won't even need a tape measure
Match the fittings OD to the hose ID.
Ask your wife/GF
Originally Posted by FF2Skip,Feb 13 2006, 03:06 PM
I never said they didn't add any extra cooling. I'm no guru, but I do remember a discussion about radiator size vs. pressure loss. I believe the conclusion was that the CT radiator was optimally sized for most applications.
Air-to-air, or the air-to-water end of an air-water-air system are where we see the charger pressure drop. ??? Am I confused?
[QUOTE=ayS,Feb 13 2006, 02:34 PM]yes, i was debating this either way. i think i'll keep the regular radiator, since it doesn't add any extra cooling.
thanks for the responses so far!
I don't know of any other aftermarket aftercooler radiators other than the Tech 2 one, which I have. I've posted before that the actual water volume in the Tech 2 is actually a bit LESS than the stock Vortech one. However, the extra area in fins may or may not make any difference in the heat transfer. I have to wait till next summer before I can compare. Comparing winter IAT with summer ones may not be a fair assessment.
mattjung2003
03-18-2016 09:12 AM
s2konroids
09-22-2012 02:28 PM
