Q for turbo owners
Q for turbo owners
How are u guys hooking up your sensors for your oil pressure/temp gauges? Are u using the Greddy oil sandwich adapter (www.horsepowerfreaks.com), or something else?
I
I
I have the InlinePRO relo kit and there is one tap for a sensor built into it.
Why they didn't drill and tap one more is beyond me.
The Greddy sandwich adapter works well attached to the block, but I don't know how or if it would work with someone else's relo kit.
I was using the greddy unit and did drill and tap it...unfortuantely I did have troubles with very small leaks and fitment so I eventually switched over to the Inline Pro kit...
I'm using the greddy sandwich plate w/ the inlinepro relocation kit. The inlinepro kit has a tap for a sensor, but i wanted to get my sensors away from the hot turbo. I've had no leaks or other issues using it this way.
Check the link in my sid. There's at least one pic that shows it clearly.
You should come out to the SoFla Supermeet next month.
The inline pro oil filter mount unit has 4 tapped holes. Since you are only using 2 (in and out) you have 2 more 1/2" holes to play with. All you have to do is get reducer fittings to fit your senders
