Pulled motor apart to find...
If it were me I'd replace the crank. That discolor you see is from heat. And also, don't try to put anything together without sleeving it when it comes to the Fseries blocks. Working in a shop doing machine work/sleeving and seeing what has to be done to the block to install each sleeve I would suggest AEBS sleeves or LA Sleeves (same thing) would highly not recommend Dartons. As far as rods/pistons- our shop/race car has had good experience with Manley.
BC stroker kit. IP stroker, Mahle pistons.....etc etc etc etc etc. Just go through build threads on here.
U should check out my F24 Blower Build, I'm repairing very similar damage. I would take the crank to a machine shop and have it measured to see if you can polish it out.
I'm sure you could do some research and find out exactly the process and I'm sure will find followers that swear by there stuff and the design but after personally machining and doing the entire process I know why our big customers never run Dartons.
The sleeve is standing on three points, press fitted and then pressed by the head, pretty logic to me, can´t sink and can´t go sideways.
I´ve used them in another car without problems and I know a 1200hp car using them as well.
How are AEBS different, looks pretty much the same on pics? Tried to use them this time but they refused to sell the sleeves.
Can´t help you with the crank, post in the WTB section, seen a few for sale.
Still want to know why Dartons are bad and how AEBS sleeves are mounted, I´m here to learn, bet I´m not alone.
I have a good AP1 crank and a set of Pauter rods if you're interested. Pulled them out of my Laskey build as I went a different direction. PM me for details / cost / shipping (from Portland, OR).
Best regards,
Stanford
Best regards,
Stanford
