PTUNING S2000 Turbo System (Pics, Dyno, Pricing)
#2691
Originally Posted by indi00' timestamp='1368681755' post='22545716
For 11-13 psi you'll best run the 2.5inch restrictor. You may still creep to 13-14psi.
My thinking is, I'm running a 3" exhaust, why put a 2.5" in there. My as well run a 2.5" exhaust?
I'm at 17-18psi on 91oct without a restrictor with lots of timing retard, daily hard driven. No worries about boost creep there. Plus what is the boost efficiency of a GTX3076R?
I'm hoping to blow my motor so I could build it.
Street Tuned Knock limited AEM EMS V2.
Haven't dyno it, but the software dyno (Virtual dyno) shows consistent 400-500 depending on what correction value you use...
#2695
ok so i bought a partial kit off the forums and i need help figuring out how to wire the oil pump to work since im running 2 fans.
if i got it right i could wire bot the red and blue wire to a 30 amp fuse and straight to the battery, then the black wire with ring connector gets grounded on the stock oil pressure switch?
let me know what you guys think, or if there is a better way to wire this
thanks
thanks
#2696
#2697
#2698
Former Sponsor
This is the vid of the S2000 you're talking about.
http://www.youtube.com/watch?v=7OUIIwDQLjI
The S2000 was running our kit with a GTX3076R using our dual exhaust.
#2699
#2700
