PTUNING S2000 Turbo System (Pics, Dyno, Pricing)
#2471
No but i do belive its like a bomb in your trunk.. What they are saying is, the s2000 is a 2006+.. Which means its a "returnless" system. meaning they can only give it as much gas as it can burn. a return system allows you to give more fuel then whats needed. All the unburnt fuel goes back to the tank.. someone correct me if im wrong.
#2472
#2475
You need to make a rectangular notch for the intake tube. I used a plasma cutter.
When the fan kicks on, minimal amount of hot air gets to the intake filter. The rest of the hot air is directed downward. I have a 2" hose from under the car to scoop cold air into the intake filter area when moving.
#2476
Former Sponsor
Trackforged Heat Shield.
https://www.s2ki.com/s2000/topic/911...ed+heat+shield
Felt peppier in stop and go traffic... no scientific numbers though.
Evan
#2477
Originally Posted by sata3000' timestamp='1351114291' post='22106252
Oh good shit! I was going to hit them up .I will now.. what radiator are you using?
#2478
Received turbo kit and gift card, thanks Andrew!
ACT Clutch + AP1 flywheel swap + turbo kit install to begin in ~1 week. Just set up 17 channels worth of AEM Serial Gauge telemetry and everything worked properly on the first attempt! E85 fuel system and ID2000s are tuned across vacuum to WOT region and car is begging for boost.
#2479
A returnless style fuel system does not have a mechanical fuel pressure regulator at the fuel rail, nor does it ever return any fuel back to the fuel tank once that fuel has been pumped out of the tank. Maintaining fuel rail pressure is accomplished by electrically sensing the fuel rail pressure, asking the computer figure out what to do when a change is needed, and then by varying the power applied to the fuel pump to maintain that pressure. It must also separately measure the manifold air pressure to figure out what fuel pressure is needed to maintain a constant differential fuel pressure. This electrical, computerized feedback loop is slow when compared to the "directly at the fuel rail" mechanical regulator system.
I do not understand why there would be a fundamental, steady-state power limitation of returnless fuel systems if the fuel pumps and lines are identical. Pure speculation: it may be that the fuel pumps employed in an OEM returnless fuel system have lower flow capacity than fuel pumps used in a similar OEM return style fuel system (since the return system's fuel pump has to pump much more fuel at light loads compared to the returnless system). Does anybody know if the OEM pre-2006 fuel pump and post-2006 fuel pumps are the same?
