PTUNING S2000 Turbo System (Pics, Dyno, Pricing)
Old 07-31-2012, 08:30 AM
  #2351
Forcedbird's Avatar
Originally Posted by liquidgsr
On the passanger side pipe that goes to the turbo outlet what is the vaccume attachment for and where does it connect to?
Mine tees off with one hose going to the boost control solenoid and the other going to the external wastegate.
Old 07-31-2012, 08:37 AM
  #2352
liquidgsr's Avatar
Okay gotcha thanks. Do you also have the ptuning vac block? If so where are you feeding the vaccume from?
  #2353
robotvoice's Avatar
Goes to your wastegate (or boost controller if you are running one)
Old 07-31-2012, 08:43 AM
  #2354
liquidgsr's Avatar
So if I am running a mac solenoid boost controller I would have the that running to one side of the mac solenoid and then out the other side to the wastegate correct?
Old 07-31-2012, 09:02 AM
  #2355
robotvoice's Avatar
That sounds right to me. Just make sure you have the right vacuum lines going to the right ports on the MAC solenoid.
Turbosmart has some good picture diagrams in their documentation and I think Grimmspeed does as well
Turbosmart Hypergate PDF
Old 07-31-2012, 09:47 AM
  #2356
herecomesboost's Avatar
Nesar, port one on the MAC needs to be T'd (one line to the bottom port on your wastegate; the other to the turbo (or chargepiping)); port 2 goes to the top of the wastegate; port 3 should be filtered.
Old 07-31-2012, 10:23 AM
  #2357
liquidgsr's Avatar
I have a tial wastegate so it only have one port so how would that work?
Old 07-31-2012, 10:35 AM
  #2358
You should have two ports. Maybe on you only have one fitting, currently?
Old 07-31-2012, 10:39 AM
  #2359
liquidgsr's Avatar
I thought on the tials its one for water port and another was the vaccume port? I will check again this weekend.
Old 07-31-2012, 10:40 AM
  #2360
You should have multiple water ports and air ports. Is your's an MVS?
Quick Reply: PTUNING S2000 Turbo System (Pics, Dyno, Pricing)
