PTUNING S2000 Turbo System (Pics, Dyno, Pricing)
Old 09-01-2011, 10:48 AM
  #1571
miguel329's Avatar
hmfic im hoping so! i parted out my fully build eg hatch had 450's, was tired of people trying to steal her.. so i parted out in jan, decided a s2000 was def for me drove one said plenty of power no need mod anything lol!!!!(told myself i would'nt do a single mod.. wife called bs) had car about 6 or so months and driving wife nuts about boost, so she encouraged me to turbo the s2000.
Old 09-01-2011, 11:41 AM
  #1572
HMFIC's Avatar
And you made an awesome decision on the turbo kit!
Old 09-02-2011, 06:58 AM
  #1573
doug@PTUNING's Avatar
Let me know if anyone need turbochargers or Ptuning turbo kits.
Doug Ptuning
Old 09-02-2011, 07:54 AM
  #1574
TerminatioN's Avatar
Ptuning,
I'm already turbo'd, but am interested in switching to your manifold (from the log I have)... what additionally (other than the manifold obviously) would it take to do this? I'm guessing at minimum I'd need your motor mounts for the manifold/turbo to clear?
What about the oil scavenging pump? Will that be required too since the turbo sits so low? Doesn't the pump have a custom bracket attaching it to your intercooler? So I'm guessing I would need your intercooler (and hotside piping, probably) too?
Ugh, this doesn't sound do-able, and I certainly don't have the money to buy a full kit. Guess I'll never have the Ptuning goodness.
Old 09-02-2011, 10:23 AM
  #1575
miguel329's Avatar
got my package def well packaged! didnt really get a good look at the stuff cuz i work sec shift tonight sucks!
Old 09-02-2011, 06:26 PM
  #1576
JspecVtec's Avatar
i looked through the instruction manual but still not sure what goes at the bottom hole of the turbocharger and the intake piping in the pics below. can someone describe to me or am i missing a part for the intake piping? thanks
Old 09-02-2011, 07:49 PM
  #1577
dales2000's Avatar
I believe the bottom of the turbo is for the oil return and coolant lines. The intake charge pipe ports gets capped off if you didn't order the fittings for that plate.
Old 09-02-2011, 08:31 PM
  #1578
dales2000's Avatar
just curious..........is GTX4202R too big to fit with this kit?
Old 09-06-2011, 06:10 AM
  #1579
sata3000's Avatar
Has there been anything done on the design of the "cool box"?Fall is getting close
Old 09-06-2011, 02:10 PM
  #1580
Former Sponsor
Ptuning's Avatar
The two open ports on the turbo center cartridge is for the banjo fittings and braided coolant lines. It's included in the package# PTP-PKG-30000-11. The -4AN restrictor flare fitting is for the braided oil feed line and the bottom -8AN fittings with the plastic cap is for the braided oil return line.
The billet welded flange on the upper intercooler piping was designed to mount our optional vacuum block in the center with the 4 screw holes (it was included free of charge for those that did the initial pre-order). The 1/8NPT port on the rear is can be used for a WMI nozzle (a 1/8NPT plug is included in package # PTP-PKG-30000-18). The port on the front of with the 3 screw hole is designed for an AP2 model with DBW that uses an intake air temp (IAT) sensor. We supply a billet aluminum plug, o-ring and hardware to plug it up if you have an AP1 or AP2 with non-DBW (the IAT plug, o-ring and screws are included in package # PTP-PKG-30000-18 as well).
MrC
Quick Reply: PTUNING S2000 Turbo System (Pics, Dyno, Pricing)
