PTUNING S2000 Turbo System (Pics, Dyno, Pricing)
Old 08-04-2011, 05:49 AM
  #1371
dales2000's Avatar
Originally Posted by HMFIC
Originally Posted by dales2000' timestamp='1312427687' post='20845331
Toan said to change it as a precautionary measure. I started my car to let it warm up. I walked away for a few minutes then got in and saw the oil light on. Idk if it came on right away or in the time it was idling but the point is I am not sure in that time if the turbo was being starved enough to cause a problem or worst case a problem with my motor. Im just posting to give people a heads up to change it because if everything is ok I figure to be lucky but if I were to let it warm up longer I could of had a bigger problem. Just a heads up.
The turbo is pretty stout. When it happened to me, i took off the intake pipe to the turbo and there was oil there from it backing up some since the pump wasn't pumping. Mind you i had the car running for a good 10-20 min before i got things figured out. It will just smoke from the oil burning off. I cleaned it up and it was good to go.
thanks that makes me feel a lot better since i haven't driven the car since i changed the fuse.
Old 08-04-2011, 07:22 AM
  #1372
HMFIC's Avatar
Originally Posted by HMFIC' timestamp='1312456856' post='20846018
[quote name='dales2000' timestamp='1312427687' post='20845331']
[/quote]
Old 08-04-2011, 07:28 AM
  #1373
OBrien@PTuning's Avatar
Location: Performance Tuning (PTUNING) 9432 Center Point Lane Manassas, VA 20110
Blucky, please give me a call today here at the shop.
-Brian
Old 08-04-2011, 12:53 PM
  #1374
metros's Avatar
Originally Posted by blizz81
metros, I know you've posted oil and coolant temps from track days, but I think the warmest track day I saw where you mentioned the ambient temp was 75-80. Have you had a track day where it was pretty hot out - ie, in the 90s air temp?
I think the max ambient temperature I would run at the track is 90*. Any higher and I think you would have to ease up after hard lapping to cool things down. Thats with the PTuning oil cooler and stock radiator. I now have a koyo radiator as well and would still be cautious with tracking in high temperatures (i.e. 95+).
Old 08-04-2011, 04:08 PM
  #1375
blizz81's Avatar
Did you notice much diff in temps switching to the koyo?
Old 08-04-2011, 06:08 PM
  #1376
HMFIC's Avatar
I've done quite a few hardcore runs back to back and the car has been tested over and over in the development stages and she always held steady. Ptuning had installed the KOYO radiator while building the kit.
I don't track my car like Jason *metros* does so he most definitely has the knowledge on this and he tracks his car pretty regularly.
On the flip side, if you don't track your car regularly or love to do spirited drives and push your car in the dead of summer like myself, I can tell you from my experience that i've never had issues with the heat and or increasing temps past 195 i believe.
Old 08-04-2011, 06:17 PM
  #1377
sata3000's Avatar
There will be a major difference with a Koyo Radiator.
Check out this thread
https://www.s2ki.com/s2000/topic/884...own-radiators/
Old 08-04-2011, 08:32 PM
  #1378
blizz81's Avatar
Yeah, I just saw that thread on the front page and went through it
I would like to be able to track my car and/or not really have weather limit me in normal cruising, as living in Nebraska, I already lose enough S2K driving time in the cold/rainy periods as is. Just trying to get my reading in...I would be looking at going FI next year so I have time to do some studying.
Old 08-06-2011, 08:03 PM
  #1379
miguel329's Avatar
Im def getting one of these kits waiting for a check to be sent to me!
Old 08-06-2011, 09:10 PM
  #1380
Batbite's Avatar
Where do I get in line to wait for one of those checks your talking about...
Quick Reply: PTUNING S2000 Turbo System (Pics, Dyno, Pricing)
