PTUNING S2000 Turbo System (Pics, Dyno, Pricing)
Old 08-03-2011, 11:49 AM
  #1351
dales2000's Avatar
Originally Posted by Blucky87
Is anyone else with the kit having problems with the oil pump? Mine is kinda loud and sounds bad anyway to check if it is working right?
are you hearing it with the ignition on or the car running? also Idk if you guys did this but you should replace the 7.5amp fuse under the dash(heater blower) with a 10amp. mine just blew and prevented my oil scavanger pump from working.
Old 08-03-2011, 12:03 PM
  #1352
sunman's Avatar
that's no good... just randomly blew the fuse?
Old 08-03-2011, 12:31 PM
  #1353
spdracerut's Avatar
That's odd. I think PTuning is using a Mocal racing pump rated at 10,000 hours.
Old 08-03-2011, 12:52 PM
  #1354
dales2000's Avatar
yea i talked to toan and he said to change the fuse to a higher one because the pump draws a lil more than the 7.5. I started the car had it running for a couple mins then got in to drive it and saw the oil light on. I hope the turbo is ok im pretty sure the motor is fine since it was just idling for a few minutes and no weird noises but that fuse should get replace
  #1355
dales2000's Avatar
the pump is loud but u cant hear it when the car is running
Old 08-03-2011, 01:04 PM
  #1356
sata3000's Avatar
I had ptuning install the kit for me. I wonder if that fuse got replaced. I'll have to check when I get home. Good find Dale
Old 08-03-2011, 01:16 PM
  #1357
07GPW's Avatar
On first start up after installing the kit my pump wasn't working and I had the oil light on. After checking everything I had found the 7.5amp fuse was blown. I just replaced it with the same amperage fuse and since (about 3000km) it has been fine.
Old 08-03-2011, 01:20 PM
  #1358
dales2000's Avatar
my car was fine for 2800miles then blew. I would replace it with a 10amp as a precaution. you have spare ones in the car already or you can buy a few for a couple of dollars. not worth the risk IMO.
Old 08-03-2011, 01:27 PM
  #1359
07GPW's Avatar
Alright thanks for the tip! Will be doing that tonight
Old 08-03-2011, 03:37 PM
  #1360
HMFIC's Avatar
Back in January when I first took delivery of my s2000 after Ptuning completed the kit, I took it straight to my paint shop for work to be done. Went to go check on something and when we moved the car, i noticed my oil light was on. I also noticed no heat. I couldn't figure out why. Naturally I called Toan and he said to replace the fuse with a 10amp. I did so, and problem solved. That fuse is connected with the external oil pump along with the heater.
Quick Reply: PTUNING S2000 Turbo System (Pics, Dyno, Pricing)
