Problem with High Boost
The other day, I felt that the car was running slower than usual. I have the AEM TRU BOOST Controller/Gauge so I checked the what the highest boost the car hit. It was like 14-15 psi which is weird because I should have hit 18.x psi.
Today, on the way home, I wanted to double check it. I checked where the boost is set at. It was set at the same boost level so I gun it and then checked the Highest boost I hit and it was only 15psi.
What can cause this? did the turbo somehow go bad? can it be the solenoid? anyone experienced something like this before?
Typically, when a turbo starts to go you will start to blow blue smoke due to the blow by. If it's not showing signs of wear then it's likely a vacuum. Check your couplers to see that they're well connected.
GL,
J
GL,
J
The only time I ever experienced this was when I had my couplers get burnt through by the turbo manifold and then when I had an exhaust leak I couldn't build boost past 15 psi.
Originally Posted by bigpurp,Nov 15 2007, 11:37 AM
I have the same issue. Then again, I also know I have an exhaust leak. Once that is fixed, I expect to be back to normal.
This morning, I wanted to see what will happen if i lower the boost to something that is lower than 15psi so see if the solenoid is OK. It turns out that it is OK because I only hit like 10-11 psi when i lowered it. I believe it is one of 3 things.
1) The line from the wastegate to the solenoid id broken because of the heat
2) Intercooler leaking
3) BOV
I hope it is the first one and I can get it fixed quick
