PPG Synchro Box - Better than you thought?
Old 12-13-2018 | 07:21 AM
  #71
LostMarine's Avatar
Originally Posted by kartectuning
It seems impossible to get a good reading vehicle speed sensor from the ppg syncrho tooth profile, it starts missing the output signal at around 100mphs..
Never had an issue with mine
Old 02-23-2019 | 07:44 PM
  #72
jzz30's Avatar
Originally Posted by hatrickstu
. I ended up pulling the trigger and also put in a Science of Speed carbon twin disk. For the better part of 2016 I fought drivetrain issues. Car wouldn't shift sometimes, grind alot, etc. Turned out my clutch had some issues. SOS was great and got to the bottom of it, but for the most part the calendar year of 2016 was wasted.
what was the issue with the clutch exactly?
Old 02-25-2019 | 05:25 AM
  #73
hatrickstu's Avatar
Long story short, I got one of the first of the "gen 2" if you will. The clutch is made by RPS and they started using a different style release bearing after Tilton had a patent expire. The RPS version didn't work well, SOS went back to the original style and all is well.
jzz30 (02-25-2019)
Old 12-09-2022 | 05:57 AM
  #74
gojessego's Avatar
How did the PPG set hold up over the last 4 years since this post was created?
Old 12-09-2022 | 06:42 AM
  #75
umair's Avatar
The PPG trans are just fine! the S2k trans has a bad name only because shops want to make money on swap kits. Uless you have an all out race car you dont need to do a trans swap.
Old 10-11-2024 | 10:17 AM
  #76
Spoolin's Avatar
You still running this trans today?
I have the Samsonas 6 spd that I am getting ready to swap in, but I keep contemplating going back to the stock trans and PPG set instead. Mine is still a street beast that will hit the track at times, so I still want the nice shifting like the stock trans but also be able to beat on it hard at the track without any worry at over 1000 whp..
Old 10-13-2024 | 04:24 AM
  #77
RAIN H8R's Avatar
PPG does not offer the gearset anymore. Last I checked, they will make 10 sets at 10,000 per set.
I recently picked up a PPG Helical synchro gearbox. So far I am happy with it, just sorting out some clutch related issues with it.
Spoolin (10-15-2024)
samson123
05-04-2016 05:44 PM
OHclassic
09-16-2012 06:46 AM
tritium_pie
08-07-2005 02:47 PM
FormulaRedS2k
06-13-2003 08:29 AM
Honda Racer
03-06-2002 08:12 PM
Quick Reply: PPG Synchro Box - Better than you thought?
