Power for gauges
Power for gauges
Where is everyone powering their gauges from? Currently I have the CT waterpump in the "C" spot and my a/f gauge in the fuse #9 spot with an add a fuse. Not sure where to power the 2nd gauge from.
You could wire in a junction block to the spade terminal under the dash. There are three by the fusebox, I think it's the middle one that is ignition powered (not 100% sure, can look at my car later). I'm not sure if the #9 that you're using now is the same terminal that I'm referring to. These are some different junction blocks you can use. You can get them at auto parts stores or places like Radio Shack.
http://www.amazon.com/HELLA-H8496009...316ETMDHRRN6V4
http://www.amazon.com/ACDelco-U1952A...junction+block
http://www.amazon.com/JEGS-Performan.../dp/B00CO6Q5BQ
That's what you need. You can run one wire for power from the switched point under the dash fuse box, and split that four ways. Basically making the one power source four.
That's what I've been using for my gauges with 5A fuses.
I believe the spade terminal c is the ignition one you are talking about redline and that is where I have the water pump. Will everything be getting enough power if I use the junction block and still run the water pump there? Someone mentioned in an older thread that his Plx gauge wasn't getting enough power when he tried powering it in the same spot as the pump.
