is this an ok vacuum line setup?
Banned
I want to make sure the way my vacuum lines are setup are ok. For some reason it's really making me paranoid. I made a separate post about my catch can and what my tuner had said. He had put a cap on my intake manifold vacuum line. I originally had the catch connected to the pcv and the intake manifold but my tuner said that I would be causing to much pressure into the catch can. Another member on here suggested putting a filter on the catch can to release the pressure. From talking to a local shop they said if I did that, it would cause a leak because of the intake manifold. I decided to leave everything they way it was from leaving the tuner. I have the pcv connected to the catch can, but no other hose coming from the catch can. The intake manifold is still caped.
^ Post doesn't really make any sense.
vent the catch to atmosphere or run it back to vacuum, doesn't make a difference. Put a breather on the front as you don't want pressure in the crank case anyway. To much pressure in the catch can??? Who is your tuner?
I wouldnt run a vacuum line to the catch can if that is what you are asking. Simply put a filter on the top of the catch can and any port on the intake manifold un used just cap off. Run your breather lines off the valve cover directly to the catch can.
Seth I think you need this type of Catch can
http://www.maperformance.com/jm-fab-univer...-catch-can.html
I have been talking to Jack (Goddrad) about by set up and he suggested the same set up as AMS. He told me cap off the intake manifold, connect the PVC to a vented catch can, and put a breather in the front..
BTW I'm going to order the same type of catch can as well...
Banned
I may not being using the technical names accurately. Here is a picture. You can see where the hose from the catch can is connected. The other hose that would come from the catch can was then connected where the cap is now. My tuner said that this is how it is suppose to be connected, but with 24psi it could cause too much pressure in the catch can. He then added the cap. I went to a local shop to pick up an adapter I needed to hook up my coolant temp gauge. I was going to buy a thread and filter and tap it into the cusco catch can to make it vented. He said if I took the cap off and tapped a filter into the catch can that, that would cause a leak.
Catch can should have 2 holes nd whatever they are using to show you a measurement for oil inside. One of the ports should come from the back of the valve cover. The other should be vented, which would allow ZERO pressure inside of the catch can, or can be routed back to the intake mani which could potentially cause a pressure in the catch can. I have a krank vent inline on my setup, it doesn't serve a purpose really.
Banned
http://www.maperformance.com/jm-fab-...catch-can.html
Banned
1. Should I just put a krankvent on the pcv and then put the old hose back on the pcv to the intake manifold and get rid of the catch can?
2. My tuner did say all i needed to do was put a check valve between the catch can and the intake manifold. Where can i get the check valve from?
s20004lifehomes
Member S2000 Classifieds and For Sale
06-30-2015 03:22 PM
