which oil to use?
Manual says 10W30.
I use 10w40 because having a turbo and hotter oil, you want the oil to stay a little thicker when hot. Hence the w40 instead of w30. Oil pressure will go up slightly also, which is fine.
general rule of thumb is to go up one weight for FI
i use Mobile 1 synthetic 10w30 ...but the last time i went to Spugen, Ricardo recommended 0w30 ...im running on that right now and it runs fine ...though i dont know what the difference is...
Originally Posted by XclusiveAutosports,Feb 9 2006, 02:17 PM
Is it still reccommended to use 10w40 for a turbo'd car if you live in a cold area like NY in the winter?
Now if they made a 10w50, that would be the perfect oil IMO for my climate(40 deg to 80 deg weather) and turbo setup.
