oil return line
Wouldn't your "kit" have this taken care of?
You can do it via the oilpan drain plug (Comptech way) or via tapping the oilpan (Vortech way).
http://www.comptechusa.com/store/media/ins...ions/ins072.pdf
http://www.vortechsuperchargers.com/...s/4hs218im.pdf
Tap the oil pan in a spot where the return line won't interfere with heat or chafing. The return hole should be tapped above the oil level in the pan as well. Use plenty of teflon tape or Hondabond/Liquid gasket.
stack
08-21-2009 05:26 PM
