Oil pressure gauge install
Old 11-13-2010, 08:00 PM
s2k dre's Avatar
Originally Posted by Fallen,Nov 13 2010, 09:46 PM
Oh okay so your saying i dont need the oem oil pressure sending unit??? Just connect the mechanical gauge instead of the unit??
Some one please verify
Yea that sensor controls the dummy light on the dash. U can use it with a t fitting if u want.
Old 11-13-2010, 08:01 PM
s2k dre's Avatar
That sensor just reads the psi, but u got a gauge already so ur good to go.
Old 11-13-2010, 09:16 PM
Spec_Ops2087's Avatar
Originally Posted by SgtB,Nov 13 2010, 09:07 PM
Make sure you're using top notch hoses and fittings. You're running hot engine oil into your cabin. I've always run electric gauges just for that reason.
Yeah, the idea of running pressurized hot engine oil into the passenger compartment scares me. I'd stick with electric...
Old 11-13-2010, 11:27 PM
RedLineS2k10's Avatar
Run 2 gauges
Oil/Boost lol
Old 11-14-2010, 07:19 AM
Former Sponsor
Moddiction's Avatar
I would not want to use a mechanical oil pressure gauge. Electric is much easier and no worries of hot oil coming into the cabin.
Old 11-14-2010, 11:24 AM
Fallen's Avatar
You guys are right ha just the thought of a hose coming loose and hot oil spilling in my face just scared me... Lol i will be looking for a electronic one NOW>
Old 11-14-2010, 12:42 PM
s2k dre's Avatar
I would mount the gauge near the pass side near the radio so u can keep an eye on the fitting at the back of the gauge! I wont leak if its done right.
Old 11-14-2010, 12:56 PM
Former Sponsor
Moddiction's Avatar
^Electric is only a few bucks more and easier to install so no reason not to get one.
Old 11-14-2010, 03:50 PM
SgtB's Avatar
Way easier to pull wires in than tubing as well.
Old 11-14-2010, 07:52 PM
siadam's Avatar
Cleanest way imo, is to use a sandwhich adapter.
Not only does it provide an easy way to pull oil from the block, it also gives you a place to feed the turbo as well, 2 birds and one stone.
mnr vortx f20c
11-27-2012 08:47 AM
08s2000CRbackinblack
07-09-2011 09:41 AM
vaamntxoovzeb
08-24-2010 09:18 AM
LHP_Sailor1P
South Florida
01-30-2006 05:13 AM
str8 6
05-06-2005 08:50 AM
Quick Reply: Oil pressure gauge install
