Oil pressure gauge install
Old 11-11-2010, 10:09 PM
Fallen's Avatar
Default Oil pressure gauge install
Hey guys i did some research for installing a mechanical oil pressure gauge and before i attempt this i want to be assured of my doing.
So im going to have a fitting running from the block into a hose. From that hose to the stock oil pressure sender and then attach a T.. Does that sound about right?
Old 11-11-2010, 10:12 PM
s2k dre's Avatar
Yea that will work the best.
Old 11-11-2010, 10:13 PM
Fallen's Avatar
Thank you man appreciate the quick response.
Old 11-11-2010, 11:25 PM
RedLineS2k10's Avatar
Idk if this well help or not, but this is how my setup is..Anodized T fitting is threaded right above the oil filter. GL
Blue piece (t-fitting)
braided line (oil sender)
silver sensor to the right (oil pressure gauge)
Old 11-12-2010, 04:04 AM
passmans2kny's Avatar
^i have the same exact set up
Old 11-12-2010, 10:14 AM
Fallen's Avatar
Thanks bro that does help me out.
Old 11-12-2010, 12:19 PM
Ilike2DRIFT's Avatar
I'm running my oil temp and pressure off of the oil relocation.
Old 11-12-2010, 01:54 PM
s2k dre's Avatar
If ur using a mechanical gauge i dont think u need the oem sending unit. But im not sure if it will trigger the dummy light on the cluster.
Old 11-13-2010, 04:46 PM
Fallen's Avatar
Oh okay so your saying i dont need the oem oil pressure sending unit??? Just connect the mechanical gauge instead of the unit??
Some one please verify
Old 11-13-2010, 05:07 PM
SgtB's Avatar
Make sure you're using top notch hoses and fittings. You're running hot engine oil into your cabin. I've always run electric gauges just for that reason.
Quick Reply: Oil pressure gauge install
