Oil pressure Gauge
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
I ordered the Autometer Electric oil pressure gauge, Part # 2634
In the description though it says it includes a 1/8 npt sender and a 1/4 NPT adapter fitting. Am I able to order what you described seperately, or do i need a different gauge?
This is the gauge I ordered...
http://www.ebay.com/itm/291061807802...84.m1497.l2649
Do i need to order this to make it work?...
http://www.autometer.com/cat_accesso...il.aspx?vid=59
thanks in advance
thanks in advance
I would rather use a sandwich plate. If you use the OEM port you lose the OEM sensor. Your oil pressure light will probably be on all the time. I rather have the new gauge from a new port and still have the OEM idiot light because after you have a gauge for 1 month, 6 months, a year you tend not to look at anymore. Takes about 10 minutes to install a sandwich plate under the oil filter. It will also give you a tap or a oil temperature which is more important. You probably will never lose oil pressure and if you do you will know it pretty quick, but you can over heat your oil and this is what you should be looking out for.
http://www.motoiq.com/MagazineArticl...erheating.aspx
thanks in advance
thanks in advance
