Oil cooler kit
Old 04-30-2007, 07:47 PM
foxer10's Avatar
Yes, those s/s lines and fittings will run you a lot of money. Youll learn to appreciate them when you see them.
Here is where I mounted mine. The core is from pegasus and we did a custom bracket to rest right on the driver side bumper inlet.
Robert
Old 04-30-2007, 07:57 PM
tukluc's Avatar
^That is slick! I have an intercooler taking up all the space in the front so I was thinking of a mount similar to what you did. Can you provide any other info? (size of the cooler, mount style, any other pictures)
Old 04-30-2007, 08:27 PM
s2guru's Avatar
check THIS kit out. what you guys think?
Old 04-30-2007, 08:31 PM
Raven628's Avatar
That is nice, as with the others I saw.
I just had the relocater kit and decided to build from there.
As we see, several ways to skin a cat around here.
Old 04-30-2007, 08:34 PM
s2guru's Avatar
how you install there system if i'm using a oil filter adaptor to feed the turbo and for the oil pressure sensor?
Old 04-30-2007, 08:54 PM
Raven628's Avatar
Does this help.
Feed line, with sensor coming out of the block where the stock sensor was.
Old 05-01-2007, 04:17 AM
CourageOO7's Avatar
Originally Posted by enrique_s2k,Apr 30 2007, 07:57 AM
I have a supercharged s2000 that is my daily driver I usally put about 120 miles a day traveling to work and home. I was interested in gettin a oil cooler kit cause texas weather is a bit hot. If anyone has ideas I would appreciate it.
Thanks
Enrique
I wonder if any turbo guys have this kind of a daily commute.
Sylvain2000
05-28-2015 04:27 AM
kutsujula
12-12-2007 11:03 AM
Soul Coughing
05-16-2007 09:22 PM
enrique_s2k
04-30-2007 04:47 AM
enrique_s2k
04-30-2007 04:45 AM
Quick Reply: Oil cooler kit
