Oil Cooler
Oil Cooler
are oil cooler really necessary for around 350whp?
I see that the greddy kit comes with a oil cooler and there only around 300.
And if it is recommended what you do you guys recommend?
Originally Posted by s2guru,Sep 28 2007, 05:48 PM
oil cooler is not necessary for 350. if i'm not mistaken they recommend a oil cooler for 500+ whp
i believe he is referring to the Greddy Oil Cooler unit.. i was debating this myself to just keep my underhood temps under check.. but i settled with a vented hood, a koyo radiator, and an EGT Gauge.
I was also curious but does it help in the case of short autox's and short track events? Because I was in the market for one and if I really don't need it, I would rather have one less place for a mistake (i.e. leaks etc...)
James D.
James D.
Auto cross ==> No
4 or more laps ==> Yes
However, it depends on your track temperature. The best thing to do is install an oil gauge. Even in a stock car the oil temp can get fairly high in Australia.
