OEM oil pressure sensor pinout on AEM
Old 06-09-2010, 12:36 PM
  #31
Spoolin's Avatar
Are you referring to the relocation block on the engine or the filter adapter that you pull your turbo oil from? I supply my turbo its oil from the relocation block on the engine. As for the oil pressure being read from there, I'm not too sure it would be an accurate reading area, but yeah, you can use that spot for a sensor.
Old 06-09-2010, 02:08 PM
  #32
TRBOKEV's Avatar
I have my stock sensor on the relocation block, and the AEM pressure sensor on the "T" coming off the block that my oil feed connects to.
Old 08-03-2010, 12:11 PM
  #33
Sarek's Avatar
Just odered the 100 psi per Kev recommendation.
What is the proper oil pressure for the S2000? is it different when boosted?
Does it ever go beyond 100psi?
wouldn't 100 psi offer better resolution?
Old 08-05-2010, 05:51 AM
  #34
tony1's Avatar
100psi is fine for the oil pressure sensor. The factory is a pressure switch, not a sensor, as has been said. You can not use a 5v pressure sensor and also have it control the light on the cluster. I would recommend using a vacuum distribution block for the oil system so there's no cluster#### of Tees and what not. Keep the factory switch there, they almost never fail and the reality is a warning light on the dash will be the first thing you notice if you lose oil pressure.
Old 08-05-2010, 07:30 AM
  #35
raymo19's Avatar
Originally Posted by Spoolin,Jun 8 2010, 11:44 PM
My concern is, if you pull the stock dumby light sensor, it wont be able to read anything and will set the oil pressure light off.
Nope - the light will stay off if you disconnect the stock switch. Ask me how I know.
Unfortunately it will remain off if you lose oil pressure as well.
Old 02-04-2011, 06:35 AM
  #36
siadam's Avatar
Any word from the people that have purchased the aem sensor from amazon?
I'm looking to order this one myself.
Old 08-12-2011, 07:30 AM
  #37
Boostaholic's Avatar
Old thread, but here is your fix for the dash issue when replacing the OEM on/off dummy sensor with a real oil pressure sensor as I just went through this myself.
1) remove the OEM on/off oil pressure sensor & replace it with your "real" oil pressure sensor of choice.
2) Wire the new sensor up to one of the spare inputs on the AEM EMS as stated above.
3) Connect the wire that conected to the original OEM on/off oil pressure sensor to one of the spare switched outputs on the AEM EMS
4) Enable the switched output on the EMS that is now connected to the OEM oil pressure "sensor" wire to open/close the circuit (turning the oil pressure idiot light on the dash on and off) based on the oil preasure reading that your new sensor provides.
5) Smile & drink a beer :-D
Best part is you can now set the dash oil light to turn on/off at whatever oil pressure you like, as oppose to whatever the OEM oil switch is calibrated to.
Old 08-12-2011, 09:23 AM
  #38
spectacle's Avatar
How did you find the wire from the stock oil pressure sensor to send to the AEM? Where is it in the harness?
Old 08-12-2011, 08:44 PM
  #39
siadam's Avatar
Thanks for the info.
- Sent from my iPad2 using Tapatalk
chrispayze
08-31-2017 12:07 AM
starrman
07-17-2012 11:34 AM
EPM04
07-06-2010 10:03 PM
Phillie
06-15-2007 04:20 PM
Boostaholic
06-04-2007 09:28 AM
Quick Reply: OEM oil pressure sensor pinout on AEM
