Which OEM coils are the best?
#42
#43
Originally Posted by s2000 or 240sx' timestamp='1351523214' post='22115287
I've done 2 boost builds my first S2000 made 499whp and my current one is making 591whp and I have had a few coils go bad on me in each build but it seemed to be more related to the mileage than anything else. Ive used ap1 coils and the first gen ap2 coils and they both seemed to work the same for me. I keep 2 to 3 extra coils just in case.
You replacing with used or new coils ?
I've never changed a coil => difficulty scale from 1-10 (for non-mechanic) ? Any special tools required ?
Thanks !
#44
Originally Posted by OHclassic' timestamp='1351526110' post='22115451
[quote name='s2000 or 240sx' timestamp='1351523214' post='22115287']
Thanks !
[/quote]
Thanks for the interesting info. May I assume there is some correlation between HP and coils (higher = bad for coils) ? I'm obviously running much lower at 500 vs your 591 and 900(!) but it would be interesting to know if others >450HP have same issues with them.
* BTW - is the coil replacement a 10/30/60 minute job ?
* How can you be 150% sure it's the coil that needs replaced and which one that needs to be replaced ?
Thanks!
#45
Originally Posted by s2000 or 240sx' timestamp='1351535120' post='22115874
[quote name='OHclassic' timestamp='1351526110' post='22115451']
Thanks !
[/quote]
Thanks!
[/quote]
you can replace all of the coils in 10 mins. Like someone said earlier you just take off the spark plug cover with an allen, then use a 10mm socket for the bolt holding each coil in then unplug them and pull them out. When some of my coils went bad my car sounded kinda like a wrx and to check which one it is you can just unplug the coils one at a time until it idles normal again then replace the bad one. The ones that would idle and drive normal but would only have a blowout under boost are a little bit harder to find. Since I lived about 5 minutes away from my tuning shop I would just take it there and normally they would connect to my aem ecu and put it on the dyno to find the bad coil.
#46
Originally Posted by OHclassic' timestamp='1351537809' post='22116038
[quote name='s2000 or 240sx' timestamp='1351535120' post='22115874']
Thanks !
[/quote]
Thanks!
[/quote]
[/quote]
Awesome, thanks !
#50
