Novi 1,000 Oil Leak - any ideas?
Hey guys I noticed an oil leak so took a look and its coming from the large braided metal line running from the SC down to the oil pan....it appears to be coming out of the junction where the line runs into the oil pan. Anybody have any experience w/ this? Is there a small gasket or seal down there that may have gone bad?
All input appreciated.........
the line just screws into the oil pan like your oem drain bolt. there is no gasket. check to make sure the fittings on both sides are tight(from the line to the fitting and from the fitting to the block).
zeroptzero
12-13-2011 03:16 AM
