Noisy CC clutch 6 puck
I need the input of current 6 puck users. Is the clutch very noisy like something is loose or vibrating? Just want to make sure it's my clutch and not something else because I've checked my car a million times and do not find anything loose.
If that's the case, will an act pp with oem disk get rid of that problem while still holding the power. I will not be running anything over 300 ft-lbs of torque....
Mine was a little chatty but not too bad. It was a sound I hadn't heard before though I wasn't sure if something was wrong. As I got better at driving it and it became more broken-in it's become quiet. I also have the light flywheel.
I installed my second CC stage 4 clutch and man is it noisy. Its nothing like the super silent first one I had. I am starting to think something is wrong.
I buzzes when releasing the throttle. Quiet when you press the clutch.
Any ideas?
I am worried since they sound so different. Almost doubting its the same type of clutch.
Any ideas?
That is just the nature of this clutch. I personally do not like it at all. It slips very little, clutch engagement is very quick, and it is a pig to get out of first gear. Yes it is also noisy under deceleration like a bad chainsaw. This is not a DD clutch IMO. It is also hard on the driveline when shifting fast.
