no boost from turbo, overheating
Old 10-08-2008, 05:13 PM
  #31
s2000_turbo2's Avatar
havin big problems man..fic has to be constantly reset and cleared in order for the car to run correctly..big pain..you hear any news on that hondata kpro??
Old 10-09-2008, 06:36 AM
  #32
9KRDLIN's Avatar
get a new tuner, the shop you had it at is obviously not a good one, especially if they claim you have to break in a turbo
Old 10-09-2008, 06:44 AM
  #33
vader1's Avatar
Originally Posted by s2000_turbo2,Oct 8 2008, 05:51 PM
my boost guage read zero boost..but i heard spooling just no boost..last night i opened the hood and noticed that my heater line melted bc it was mounted too clost to the manifold wtf
If the car knocks like hell and you are running a cat you might have plugged it up. Are you running one or a test pipe?
And yes, it sounds like your shop of choice might suck.
Old 10-09-2008, 09:29 AM
  #34
test pipe..no cat
Old 10-09-2008, 10:55 AM
  #35
05TurboS2k's Avatar
^ curious.... how much vacuum are you showing at idle?
Old 10-09-2008, 12:49 PM
  #36
kutsujula's Avatar
are you sure ur boost gauge just aint working?
Old 10-09-2008, 01:12 PM
  #37
i believe it was right around 118-128 if im correct...well i did a compression test last night...and failed with flying colors..130..60...95...20...i thinking a blown head gasket and warped block...funfun
Old 10-09-2008, 08:38 PM
  #38
9KRDLIN's Avatar
wow, if i were you i would take it to a reputable shop NOW and get a lawyer to get your money back from the retards that installed it.
Old 10-10-2008, 07:38 AM
  #39
jettfiery's Avatar
wow, that sux, and all at 3500 miles. It sounds like ur 'reputable' installer/tuner isn't so reputable. And it kinda sounds like u drove it a lot more times than you should have.
Old 10-10-2008, 07:44 AM
  #40
05TurboS2k's Avatar
wow......... omg, lawyer time.
Not to insult your intelligence but did you have all spark plugs out during a compression test when you cranked over? Also did you have the throttle to the floor wide open? ALSO did you pull the fuel fuse so that you didn't wash the oil away from the seals (i forgot this one when i did mine)
If you did all those, do me/you a favor and do the same test and drop a little bit of motor oil down inside through the spark plug holes, let's see if your compression instantly gets higher from that. You need just enough to run along side the piston and drip along the edges to improve the seal.
-G
OH... AND SUE THE SHIT OUTA THAT INSTALLER!
Quick Reply: no boost from turbo, overheating
