Nitrous
Thanks JdmPearl Ill reply here. Quick summary as I grow tired of same questions over and over. 75 shot max on stock ecu although I highly recommend an aftermarket solution. 275-300whp depending on your mods. I highly suggest a wet kit. If you ever plan on going bigger then 75 shot get a direct port setup.
I have/had a ZEX wet kit on my car. I haven't used it in couple years. It was easy to install (electrical stuff was kind of a PIA though). Make sure you get an Air fuel ratio gauge to keep an eye on things. I have a lean cut off switch on my kit, meaning if it goes to lean for a fraction of a second the kit shuts down. I can answer some questions if you have any.
