New Vortech Kit Knocking
I just installed the Vortech kit with the Hondata reflash on my 06 and I have a knock from about 3500-4500 RPM at WOT. I installed new plugs (NGK BKR7E gapped down to .025) as suggested by a few people and still have issues. Anybody have any insight or suggestions?
91 octane from Shell. Wideband will be going in next week hopefully. Wanted to run in the autocross on Sunday, but if I can't get this taken care of, that's out of the question.
Called Vortech, was told to change the plugs (which were already on the way, nobody in town had them), can't reach them again until Monday.
No 93 available here. I've checked everything I can think of for a rattle. If that's what it is, in my experience it happens whenever you're at that RPM range, not just at WOT. If I can't get it taken care of, I'll dump in some octane booster just to see. That may shed a little light on the problem, but it certainly doesn't fix it.
I assume your running the stock 6-7psi kit? You shouldnt have any pre ignition since timing isnt an issue on a centrifugal charger at this level, but you may have some detonation caused from low 91 octane and stock heat range plugs. You also may be running a poor afr and need to make adjustments there, you have 3 things to take care of. Likely doing one or all three of these will eliminate your problem.
