New Turbo Oil Cooler
Hmm... I guess that could work
I just got the oil cooler kit from Inline. Basically it adds an "air-to-oil" cooler. It's installed behind the IC and in front of the radiator. I actually really like the way it turned out That seems like less work than re-routing coolant lines anyways doesnt it?
I got the turbo kit before they offered it with the oil relocator as part of the kit, so I ended up getting both the relocator and cooler at teh same time. If I remember correctly, I paid I think $700 for everything. You can check with them how much just the cooler would be for.
And yea it is routed using the relocator kit. I actually really like the way it looks. You see the 2 blocked off holes on the passenger side of the oil relocator? Well those would be opened up so you can connect hoses to those. The way mine is set up is that the lines from the motor/turbo/etc are on the side that are blocked off for you. The oil cooler lines are connected to the side that you have your lines connected to right now.
This would be much simpler with a picture or two, but I can't find my camera right now
I can post some up when I find it if you want...
The UR turbo kit oil cooler already does this and has been since the beginning.
Originally Posted by PRS2K,Aug 10 2006, 09:34 AM
I didn't know that . Do you happen to have any pics of it?
http://automotivespeed.com/product_info.ph...&products_id=50
There is a pic of it on there. As you can see it has a longer piece.
I was thinking he wanted to see a picture of it together with the oil cooler on.
