New FB340 Intank Fuel Pump
Old 08-02-2011 | 05:58 AM
  #131
EOE's Avatar
EOE
Hmm, okay where do I purchase this fuel pump? Need it! lol
EDIT:
Never mind found it....
http://fullblownmoto...fb340-fuel-pump
answered my own question too by looking at their site...
The 340 has over 30% more flow than your 255 pumps and is perfect for applications that demand more flow while keeping the existing stock wiring.
Old 08-02-2011 | 06:01 AM
  #132
camuman's Avatar
Originally Posted by EOE
Will this eliminate the need for a rewire that everyone seems to be doing with boosted cars to up the voltage? I am looking to keep stock wiring and hopefully resolve my lean condition in VTEC I am dealing with.
If not I'll just rewire my Walbro to run str8 from the battery.
while i am not a pro mechanic nor a shop owner, i can tell you this. the pumps provide more flow if you provide them with 14volts as opposed to the 10-12 they see on teh stock wiring. rewiring the pump helps at higher power levels, but its so easy to do, why not do it now that way when your ready to jump up its all ready done.
i rewired my walbro and it sounds healthy now wish this fb340 pump was out when i was first doing the pump swap. one day i will swap to this pump.
Old 08-02-2011 | 06:15 AM
  #133
EOE's Avatar
EOE
Yea but I rather keep the stock wiring and get rid of the annoying buzzing, whining, and singing my Walbro produces.
Old 08-02-2011 | 06:57 AM
  #134
camuman's Avatar
the fb340 pump is much quieter then a walbro. you dont have to rewire, but its a good idea for the long haul. so what is your ultimate goal powerwise? what is your setup?
Old 08-02-2011 | 08:23 AM
  #135
EOE's Avatar
EOE
Details here: https://www.s2ki.com/s2000/topic/871...#entry20838828
But to give you a quick overview...
Comptech SC @ 7psi. AFR in VTEC Stuck @ 13.1 and Fuel Pressure Regulator has 5 turns to go. I turn it 5 times and bottom it out, low end becomes pig rich but VTEC stays at 13.1 AFR. Wtf? I turn it all the way down last 1/2 a turn and it spikes to 13.8 in top end and low end feels like ass.... Back off and lean it out and its back to 13.1.
I must be lacking fuel up top, I am hoping this pump will resolve it and yield the 12-12.5 AFR at the top END.
Old 08-02-2011 | 08:40 AM
  #136
FullBlown's Avatar
Former Sponsor
No EMS? our pump will flow more then the walbro but I would recommend getting some sort of engine management if you don't already have one.
Old 08-02-2011 | 08:47 AM
  #137
EOE's Avatar
EOE
I hear yah. However with such low boost it's just a little more I need tO make it work. I wasn't looking to make more power and wanted to be done here. It's not worth $$$ wise to dump all that cash at this point.
Anyways if this doesn't work I'll throw the catty back on and that should fix it. But anywho.
Can you guys get the pump to 02138 by Friday?
Old 08-02-2011 | 09:20 AM
  #138
JawKnee's Avatar
Keep me posted EOE. My AFRs are totally safe with my base SOS 6 psi on my '05 with TP, TB, etc. I was thinking of either re-wiring or getting this pump even though my AFRs are totally fine (12.0/12.1 for the most part in 3rd gear and up at redline). My hope was that by either the rewiring or using this pump would allow me to decrease or lean out the RRFPR so I'm not running so rich elsewhere. Hopefully that makes sense?
Old 08-02-2011 | 11:07 AM
  #139
EOE's Avatar
EOE
Will do.
FullBlown
I cant order and getting the following error.
"Error: 3-1-5-P---A valid amount is required.
Error: Failure in Processing the Payment (ps_authorize)"
Old 08-02-2011 | 01:02 PM
  #140
FullBlown's Avatar
Former Sponsor
Will do.
FullBlown
Please call us and ask for justin. We can still ship today and you will have it by thurs-fri
Quick Reply: New FB340 Intank Fuel Pump
