New FB340 Intank Fuel Pump
#113
Thanks again for everything LJ, including all the annoying phone calls. The pump is working great, a lot quieter then the walbro it replaced. Also made great numbers on E85 with 1600s. Car put down 621whp@22psi on a mustang dyno.
Martin
Martin
#114
No problem bud, hit us up if you need anything else or if you had any questions. BTW That is really good power!
#117
Will two of these pumps in your dual pump hanger work well with id 1000's on e85? How much should that setup be able to support? Or should i upgrade to 2000's for e85? Already have the id 1000's and dual pumps but thinking about running e85
#118
Injectors will hold u back at that point. Id2000 ftw. Dew it!
#120
Originally Posted by DFWs2k' timestamp='1308360345' post='20694756
[quote name='s2000Junky' timestamp='1308360071' post='20694745']
So this may be a dumb question but wanted to make sure, is this pump a direct OEM swap into the OEM sock/housing like the Walb255? I think mine is on the fritz so might be looking for a good replacement.
yes it is
[/quote]
another vouch for the FB340 fuel pump! thanks LJ Just installed it the other week and it was a direct OEM swap and I've never had a walbro 255, but I didn't hear any whine that some walbro 255 owners mention about
