NEW ?
Old 12-27-2005 | 10:26 PM
C4SxM5's Avatar
Default NEW ?
UPDATE
Trying to get some more power now and wanted to know what size pulley I should get to get as close as can to 10lbs of boost?
Right now I have a 3.3" pulley and was able to pull 9.37lbs of boost at 8287RPM's. Want to get 10lbs at the same RPM's, so let me know what size pulley you guys recommend.
What do you guys think? Good numbers?? Not to familiar w/ Dyno sheets, so any input would be helpful. I do know the car feels a lot faster and V-tec at 4K feels a lot better than at 6K
Here's what I added to the stock CTSC:
ASP 3.3" pulley w/ GoodYear Gator 4060385 belt (should have gotten 3.25" to get the full 10lbs, but I was chicken
RC 750CC
NGK 7173
EMS 1052-U
Originally I had 285HP, so I'm happy with the new numbers.
Wanted to thank Shawn and Eric @ Epic for the help. And Phil (sideways) & casterdog for the hospitality
Old 12-28-2005 | 06:28 AM
Birdie's Avatar
probalby will make more power with a smaller pully to get the full 10psi. 9.4psi at 366 is not bad. Graph look smooth
Old 12-28-2005 | 08:42 AM
Halo's Avatar
Did you ever dyno your car on that particular dyno stock? This is the single most important piece of info to give you some idea if your gains are 'appropriate' (whatever that means).
I'm only saying this because the chart says 'flywheel horsepower' and once an arbitrary correction factor is used to calculate that, I think the numbers can be all over the place. Did you have 285 flywheel hp before the upgrade? That is a number most people get at the wheels with the stock pulley.
Old 12-28-2005 | 08:45 AM
Black Nugget's Avatar
Very nice! I wish I could figure out how everyone is able to get a continually rising horsepower. My tuner said even lowering vtec engagement he still couldn't get rid of the pre-vtec dip. And your torque numbers are amazing!
Old 12-28-2005 | 09:44 AM
C4SxM5's Avatar
i never had the car dyno'd stock, but got 285 at the wheel with the stock CTSC.
Old 12-28-2005 | 11:33 AM
nsx2fast's Avatar
hey... how about me???
Old 12-28-2005 | 12:16 PM
Sideways's Avatar
[QUOTE=Halo,Dec 28 2005, 10:42 AM]Did you ever dyno your car on that particular dyno stock?
Old 12-28-2005 | 12:17 PM
XclusiveAutosports's Avatar
Nice #'s
Old 12-28-2005 | 01:14 PM
C4SxM5's Avatar
my B thanks for the exhaust
Old 02-16-2006 | 09:42 PM
C4SxM5's Avatar
bump for new ?
s2kseven
06-13-2019 11:17 AM
SLINKYDOG
03-18-2019 06:38 PM
EriS2k
06-17-2015 04:27 PM
99SH
07-10-2012 06:30 PM
Sideways
09-25-2007 09:37 AM
Quick Reply: NEW ?
