Need to update my info on max boost used
I would love to see this stay on topic and see real answers. As long as you have supporting mods what would be the "magic" number on stock compression?
I for one am only running 6.5psi turboed.
1 Post
Originally Posted by jakub2000,Jun 17 2006, 05:21 AM
turn it up man, 8psi is the minimum you have to run to be alowed to talk to us
Originally Posted by gotswap,Jun 17 2006, 08:46 AM
There has to be..... B-series motors will only handle about 10-12psi psi on the stock compression and ~18 psi with rods and pistons before the cylinder walls go. Ask me how I know this.
Aren't our sleeves supposed to be much stronger as they are FRM?
without timing control you can kill sleeve with low boost pressures due to high cylinder pressures, With high boost on stock sleeves you need to stay away from mbep.
turbo cars are a little harder on motors due to they come up on boost when coming up on peak torque and that is when you have rapidly rising cylider pressure where sc car comes on liner and slow and that is allot easier on the motor
