Need some advice on hardware w/
Former Sponsor
I am planning to run much higher boost level.
I'm getting AEM EMS with 750cc injectors.
The problem is the fuel in Korea, where it is near 91-92 Oct
At stock boost level, I sense no detonation.
I have no idea how much boost I can make safely, or wheather I need 2mm gasket to lower the compression ratio to run on pumped gas.
1. What would be highest possible boost pressure I can run w/2mm gasket or without any gasket? (on pumped gas)
2. Would you recommand 2mm gasket with 11psi pully for safe/reliable street setting? or will 2mm gasket compromise the output too much?
3. Any recommandation??
AusS2000
06-19-2007 05:38 PM
gusrock77
09-25-2006 07:37 PM
