need help real fast
need help real fast
hey i just got a supercharger installed about a week ago everything went fine till last night, decided to test the car went WOT on 3rd 4th and half of 5th till teh check engine light turns on and stays on blinking, engine idles hard and shaky now don't know what happen but any help and input would be appreciated thanx.
Did you pull the spark plug like Folex187 said.
Are you using stock plugs? They are too hot you could have nuked one .
Do you have a wideband gauge? or have you ever dyno'd it with a wideband to see what your A/F is?
Make sure your ESM wires are all connected right and tight. Mine did this when one of the wires came loose, it wouldn't even rev past like 3,500 and idles horrible. When ever I reset the ecu it would go away, but when I would floor it I noticed that the VAFC read +0.01bar on the pressure sensor and this is not supposed to happen with the black ESM box. Try checking that first.
Originally Posted by Asura,Aug 20 2005, 11:42 PM
It doesn't sound like you got it tuned.
Sounds like a misfire. Pull the codes with a scan tool immediately. Do NOT reset the ECU.
called vortech up and they told me to pull the whole blackbox out and see what happens, so i did but the car still idling pretty bad and cel still on. so i went ahead and scan the codes it read p0301 and a p1399. oh yeah and i was actually driving like this for a bit, don't know if this would hurt it more no not but vortech said it shouldn't. what should i do now either take the charger off then take it to honda or leave it on.
any input would he helpful thanx.
