Need help on my build.
Old 02-06-2014, 03:43 PM
mandrocortes's Avatar
@cujet- Man that sounds like such a headache, unfortunately I don't have "too much" money to play with and i'm doing it myself so i'm looking for a somewhat simple set-up with a bottom mount flange. I heard pfab was also a pretty good brand for a log style manifold. I would love to have a test pipe but unfortunately need it for emissions. Although i might just swap it out when the time comes lol
Old 02-06-2014, 06:38 PM
cujet's Avatar
Don't be discouraged. One other problem on my car is that the turbo is a bit too big for my needs. Also, If I run with just the downpipe, it's remarkably more responsive.
The Inline Pro manifold is a very high quality unit. Some guys making over 500HP with it are doing some internal porting to smooth the flow a bit better. Also, the manifold has a bit of an advantage over a typical log manifold. As the Inline Pro has longer and straighter runners.
But, I may take the time to fabricate a true header for my car. It should be worth some HP.
One thing I forgot to mention. I have the 3mm head gasket, which reduces low end torque substantially. Might be better to run a stock headgasket, stock compression and less boost.
Old 02-06-2014, 08:54 PM
I was looking to run about 10 psi max boost to start off due to my turbo being used. I plan on keeping all the internals stock as well and just focusing on the correct tune and set up. I know I for sure have to get the hondata k-pro due to emissions and set-up I want. In the mean time ima run a 70mm invidia test pipe with a CEL fix. And when emissions comes around just swapping it out.
surfer_crx
03-14-2015 09:25 AM
driftintherain
09-07-2007 06:01 AM
jdnissanz
12-15-2006 11:57 PM
mikecl713
02-11-2004 05:01 AM
AndyDoh
06-30-2003 11:40 PM
Quick Reply: Need help on my build.
