Need help deciding what turbo to go with
I am having trouble trying to figure out what turbo to go with. I am going with a Full Blown turbo kit, ID1000 injectors, and FB340 fuel pump. I am looking to make close to 550whp. I know I want to go with a Borg Warner turbo and I want similar performance of a GTX3576R. The quicker the spool, the better.
Thanks Guys!
Thanks Guys!
Thanks Guys!
Thanks Guys!
Thanks Guys!
Thanks Guys!
FR EFR 7670 .92 kit here and, at 16lbsmy clutch is slipping. ID1000's but Walboro 255. In the process of putting a twin disc in along with the high boost canister for my built motor. I'm looking to max out the fuel pump around 550 probably around 20-24psi. I think in order to max out this turbo, i'll need E85 with ID2000's and a bigger fuel pump. I want quicker spool rather than top end to keep this more of a street car. I'll be happy* at 500whp though.......
Thanks Guys!
Thanks Guys!
I don't think an EFR 7670 on our car will get quite to 550, it just doesn't have enough flow up top. I came short of 500 on E85 and 20+ lbs. 8374 will fit better but sacrificing spool. I wish there was something in between the 7670 and the 8374.
Any engine or head work done?
[/quote]
No engine or head work done. Looking to keep the motor stock for now and when the time comes, build the bottom end. Thanks for the suggestions guys. I think I am going to with the S300SX 8375 Turbo S360. 550 is the dream, around 500 is the expectations.
[/quote]
