need a base map for AEM EMS
Hello, I am upgrading my CT SC Kit. I have an AEM EMS, 11PSI pulley, and ID1000 injectors. I will probably be throwing the parts in this week but I need a base map for the EMS so i can drive to the tuner. can anyone help? I am a little new to engine management systems. I just need something to get to the tuner and maybe drive around town a couple days before. I wouldn't go over 4k RMP or 30% throttle. my only other option is to tow the car or drive their with the stock EMS and stock injectors then switch before the car gets on the dyno.
well does anyone have a base map? A flat bed seems unnecessary. Maybe if it was a turbo setup but it isn't. all I really need is a tune for a stock s2k that compensates for the injectors. I can easily drive around without making any boost. hell I could even take the sc belt off.
AEM gives you a decent base map. On stock injectors, it drives like stock. It's in their library; just stay out of boost. If you want to use your id injectors, use the injector wizard and the ems will adjust your duty cycle. It won't be perfect, but should be close. Your cold idle enrich may be off, but again, it'll get you to the tuner. If you have a wideband, you can clean it up some.
I did talk to my tuner though and they said if i stopped in before that they should be able to make me one. i just have to drop of the ems for the day. Still it would be nice if i had another basemap incase something goes wrong with the tuner. I will check the library feature if i can find it
