My Turbo S2000 Monster
#22
I've made a couple of these before but here I have included my current setup with a generally accepted stock setup from Comptech's website. I don't think anyone will dispute that the stock numbers here are a good representation of a random stock car's performance. For giggles, I've included the base Comptech + AC setup (also from the Comptech website).
No flaming please...its pretty obvious the boost levels are very different. This is just to give everyone (and myself) a reference to what my dyno chart means in more realistic terms. And with X and Y axes starting at zero...
#23
maybe you should put a cut out on your exhaust so you can open up some power when you want it for the track. Looks awesome man. I would be looking to keep a stock sounding if I go the FI route a well.
#26
Originally Posted by j_c_a,Feb 17 2007, 08:14 AM
Welcome to the 400+ club Enjoy and just be careful. Every once in a while, that kind of power can jump up and bite you in the ass if you're not paying attention.
#27
Awesome!!! I'll never forget the feeling of downshifting from 5th to 4th at about 70 and flooring it and almost losing the rear end. Be CAREFUL, but have fun. It won't get old, that I guarantee you.
#28
Congrats! What tires are you running now, stock? That is kind of crazy for the ass to come out in 4th gear! I have zero traction issues with my car, I know i'm making less power, but I think it might also have to do with tires. Maybe that will be your next upgrade. Best of luck with the car.
#29
Wheels and tires are stock. 16" Potenza S-02s. Not exactly "grippy" in cold weather.
It's just that there is so much damned torque in the mid-range that the tires are overwhelmed. Come spring I'll be switching over to Goodyear Eagle F1 GS-D3s (probably) and retaining the stock wheels. I don't think its anything a little throttle modulation can't handle. Like I said earlier, the boost comes in a very linear and predictable fashion. But VERY quickly.
I am currently running UK alignment specs and I'll most likely switch back to the US specs to achieve better straight line stability. Negative 2.1 degrees of rear camber is awesome for cornering but -1.5 might be a better compromise to help put the power down.
Some nice 9 or 10 inch wide rear wheels would be fantastic though
