My turbo build list....
Old 04-01-2008, 09:49 AM
AndyFloyd's Avatar
Default My turbo build list....
Here is the list of parts I have ordered for my turbo build. Its kinda a mish mash of parts, but will be just as complete as any kit out there.
GT3076R .82 a/r
PFAB log manifold
PFAB 3" stainless downpipe
PFAB stainless Dumptube
Tial 50mm bov
Tial 38mm wastegate
AEM EMS 1052
Precision 750's
Walbro 255hp
PLX wideband
ACT HD clutch kit
GReddy Ti-C 80mm exhaust
Still need to order
Precision 600hp IC
AEM true-boost gauge/controller
IC pipes ( going custom here )
So I know i have everything I need and here is what I am wanting to do with it. I want one 93 octane map and then one 110 octane map. I have race gas available locally for 5 dollars a gallon. I was thinking 10-11psi on 93 and 15-16psi on the 110. How many people run stock compression and race gas at 1 bar of boost? I just want to make sure I can do this with stock compression safely. I am pretty sure 16psi is safe on 110 but just wanted to see if someone else is doing the same kinda thing I am.
I am hoping for about 360-380 on pump gas and 430-450 on race gas. Think its doable? Anyways, when I get some of these parts in ill throw down some pictures, but as of right now I have nothing to show for it...hehe.
Old 04-01-2008, 11:05 AM
blkwidow's Avatar
Are you doing custom oil feed and return lines? Aftermarket Fuel Pressure Regulater?
Old 04-01-2008, 11:43 AM
AndyFloyd's Avatar
I forgot to add, I also purchsed an oil feed/drain kit from them as well. I dont think Ill need a fuel pressure regulator, ill have 750's and that should be fine with the stock fpr.
Old 04-01-2008, 12:56 PM
phils2k's Avatar
check out this thread might help, the manifold is not the same but the rest of the parts are nearly
https://www.s2ki.com/forums/index.ph...ic=568314&st=0
Old 04-01-2008, 01:21 PM
AndyFloyd's Avatar
yeah phil your car is sick!! I have watched those dyno videos way too many times, so much infact that it may be unhealthy to watch them anymore...lol. I know mase made a lot of power on pumpgas but hes also a super badass tuner. Not saying the guy tuning my car isnt...I just wanna make sure 16psi on 110 isnt pushing it too far....dont wanna blow her up.
Old 04-01-2008, 01:57 PM
AusS2000's Avatar
You'll be wanting to upgrade that MAP sensor too.
Old 04-01-2008, 02:06 PM
AndyFloyd's Avatar
is there a gm sensor that is plug and play that I can get cheaply from autozone, or napa? If not where can a purchase a 3 bar map? Thanks!!!
Old 04-01-2008, 02:09 PM
AusS2000's Avatar
Yep, the GM 3 bar is one option. Or the AEM 3.5 bar. That AEM EMS comes with configs for both.
Old 04-01-2008, 05:17 PM
AndyFloyd's Avatar
great, thanks!!
Old 04-02-2008, 08:46 AM
passmans2kny's Avatar
16 psi and race gas on stock compression, I'd be scared
Quick Reply: My turbo build list....
